Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Exterior/bodykits/Lighting
Exterior/bodykits/Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 06-02-2007, 11:28 PM   #1
ricmont
ricmont Normal reputation
Question Head lights help needed!!!!
Does anyone has any advise on how to clean de inside of the head lights on a Honda Accord Lx 2001? It seems that is kind of dirty inside, I clean the out side very well but it looks like the problem is inside. Any help will be aprecited!
ricmont is offline   Reply With Quote
Old 06-03-2007, 09:05 AM   #2
SILVER2KCIVIC
SILVER2KCIVIC's Avatar
SILVER2KCIVIC Normal reputation
Re: Head lights help needed!!!!
Hi u got few options first is go to auto parts store an they might have a headlight cleaner kit.Or u can take headlights off car an take bulbs out an take somthing long an stick to hole an try to clean some dirt out or u can just take headlights apart witch I do not advise I did this on old pair lighs of mine an real mess u can heat them up in oven for like 2 mins on 400 deg an take them out an the gray headlight sealent will loseing up an u can pull headlight apart with flat scew driver but like I sayed its a pain an a mess an after u clean them put them back together an back in oven for nother 2 mins to heat up the sealent to get it soft again an then push headlight back together but if was me I just try clean them best u can an live with it or buy new one's.
SILVER2KCIVIC is offline   Reply With Quote
Old 06-03-2007, 10:29 AM   #3
ricmont
SILVER2KCIVIC, thank you very much for your advice.
Old 06-09-2007, 01:58 AM   #4
00accord44
Homie Don't Play That
00accord44's Avatar
00accord44 Normal reputation
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
Its honestly not that hard to take apart your headlights if you take your time and do it right. You'll need a heat gun or at least a hairdryer tho so you can pick your heat points and do it at your own pace. I'll see if I can find the link to the guide I used.
EDIT - Couldn't find the one I used but here's a DIY thread
00accord44 is offline   Reply With Quote
Old 06-13-2007, 03:45 PM   #5
Adam_rex
Adam_rex Normal reputation
just curious. but why would someone need to clean the inside of a headlight? if you keep the bulb in 90% of time then you shouldnt be gathering dirt in there. i mean they are sealed to keep water out. and if you dont have bulbs in. well i dunno why you have them.
1993 Nissan 240sx
1992 Nissan 240SX SE
--Parts Car--
1992 Camaro Z28
--blown up--
--getting 350 put in--
1993 Honda civic Del sol
--B16A swap--
--1997 jdm front bumper--
--1997 jdm fenders--
--Upgraded internals--
Adam_rex is offline   Reply With Quote
Old 06-13-2007, 05:52 PM   #6
00accord44
00accord44's Avatar
Depending on the type and quality of bulbs you use, they give off certain amounts of gasses into the housing and over time it will haze up from the inside. Thats why you may see people with yellowed headlight lenses. Aside from that, dirt could slip in while changing a bulb or worse than that, grease and oil. Any of those things combined with the heat caused by the bulb can dirty up the lenses from the inside.
Old 06-14-2007, 11:01 AM   #7
cbalde04
cbalde04 Normal reputation
You may also want to try using a bottle brush from the baby section at walmart. It will work for the headlights that dont have the cone in front of the bulb. you can bend the brush to scrub the hard to reach places.
cbalde04 is offline   Reply With Quote
Bookmarks
Google
Web AF
