Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 06-01-2007, 09:31 AM   #1
D9Guitarist1
D9Guitarist1 Normal reputation
Ecotec head swap onto 2.4L bottom end
I just want to know if this is possibile. MY brother did something similar to this on his Toyota Celica, and it worked great for him. I have a 99 Z24. He wants to take the head off a 2.0L Ecotec and put it on the 2.4 bottom end. He says with the smaller combustion chamber it'll up the compression ratio, and give me the benefits of having the ecotec setup. My question is, is this possible, and which ECU sould I use on this setup if we did do this?
D9Guitarist1 is offline   Reply With Quote
Old 06-01-2007, 11:24 AM   #2
Z24cavalier
Z24cavalier Normal reputation
Send a message via AIM to Z24cavalier Send a message via MSN to Z24cavalier
Re: Ecotec head swap onto 2.4L bottom end
idk sounds kind of sketchy to me and idk how the head would really change the combustion chanmber? the combustion chanmber would be the cyclinder and you not touching those so i really do not know if that would do good/bad for you. Also would the heads off of a newer ecotech even fit on a 99' Z with the 2.4?
Z24cavalier is offline   Reply With Quote
Old 06-01-2007, 09:24 PM   #3
millrtime
millrtime Normal reputation
i doubt it....the bolt pattern and all that jazz proly doesnt line up. u would proly just be better off getting an actual ecotec engine and swapping it in, because with all the custom parts u are gonna have to make for it to work, you could probably just get a new engine and mod it. the only circumstance that it could work was if the 2.4 and ecotec blocks were modular, but they arent. the only cars i can think of that u can do that on are the older 5.2 and 5.9 dodge's and older ford v8's because the blocks are the same, just milled out to different bores. and i severly anyone did it with a celica. the only other 4 cylinder i can think of toyota making is the 2.5 in the camry, and i KNOW those dont match up.
millrtime is offline   Reply With Quote
Old 06-02-2007, 05:16 PM   #4
OverAllComa
OverAllComa Normal reputation
Send a message via AIM to OverAllComa
Okay, I'm not going to give an "I doubt it answer," but rather a "that's not ever going to be possible" answer.
They're two totally different motors.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
OverAllComa is offline   Reply With Quote
Bookmarks
Google
Web AF
