99 Cherokee Wont StartMWRWB 05-31-2007, 07:23 PM Hi I Have A 99 Jeep Cherokee And Wont Start, Check Spark No Spark, Check Dist Wires And Plug All Good,put A Test Light On The Coil No Power From Coil Or Plug Before The Coil, So I Pulled The Interior Dash Under The Steering Wheel Down And Test All Ignition Wires Under There, There Was Power There. I Also Have A Remote Starter On The Vehicle, And Power Going In And Out Of All The Connection. Im Stumped, Any Ideas Would Be Great. Thank You Rick AlohaBra 06-02-2007, 11:06 AM Are you saying it cranks, but won't start? Or...it won't crank and won't start. Use a voltmeter, so you can have an idea of poor connections or just low battery voltage. That remote starter could be bad or have a bad connection. Again, use a voltmeter to trace. MWRWB 06-02-2007, 02:33 PM hi thanks for the info it does crank and wont start no spark, i tested the computer and it turned out bad, had to get another computer, the only thing is the numbers on the computer i purchased are the same but there was one letter that was different, jeep starts and runs though. do you know if that can be a problem later? the #'s on the orig comp were p56041 493ae the new one are p56041 493ad, thanks for the help Are you saying it cranks, but won't start? Or...it won't crank and won't start. Use a voltmeter, so you can have an idea of poor connections or just low battery voltage. That remote starter could be bad or have a bad connection. Again, use a voltmeter to trace. AlohaBra 06-03-2007, 01:13 AM That is probably Ok. The last digit is most likely a version change. Did you get it new or refurished? If it is used and refurbed, they might have reflashed the firmware, but at any rate it is close enough. MWRWB 06-04-2007, 08:01 AM Hi thanks for the info on the computer, that willput my wife mind at ease. This vehicle is her baby and everything has to be perfect. Thanks again That is probably Ok. The last digit is most likely a version change. Did you get it new or refurished? If it is used and refurbed, they might have reflashed the firmware, but at any rate it is close enough. Automotive Network, Inc., Copyright ©2012
