airbag code 13Skip202003 05-31-2007, 04:07 PM what does it mean? recently had a problem with a bad ground on my ccrm. very recently. airbag code began flashing, before I solved the ground problem. I did unplug the airbag sensor while investigating, pretty sure thats when it started flashing. how do I reset it, assuming nothing is wrong with the airbag? Johnny Mullet 05-31-2007, 10:01 PM What year Taurus? I can get you the answer when you give me the year. Skip202003 06-01-2007, 08:44 AM Right, I forgot. 92 . with a 3.0 L Johnny Mullet 06-01-2007, 09:52 AM I am sorry, I can only get info on 1996 and up models. Hopefully someone else can. TaurusKing 06-01-2007, 07:57 PM Well, from what I'm reading, 13 says that the airbag circuit has shorted to ground, also the diagnostic monitor will blow the internal thermal fuse while flashing 13,, monitor must also be replaced as fuse is not serviceable,, short must be found before monitor is replaced, especially if it is intermittent,, I would recommend you have an experienced airbag person diagnose this issue, for safety's sake, yours especially.. most sites will not entertain any airbag questions for that reason.. Skip202003 06-02-2007, 09:26 AM Thanks for your input,but since the car is weeks away from the junk yard, I just do the old electical tape fix. JohnMcHugh1 06-04-2007, 06:06 PM My 1994 Taurus Wagon has same issue. Did you ever cure your CEL 13? Skip202003 06-16-2007, 11:57 AM No, I just let it keep blinking, but I covered the light with tape so it won't distract me. Automotive Network, Inc., Copyright ©2012
