wiper sprayer
mike561
05-31-2007, 03:10 PM
My pump doesnt work for the wipers that sprays the windsheild, i took apart the pump and after inspection, it doesnt look like a pump, rather its a motor that spins a little fan type thing and i geuss thats what pulls the water out of the fluid tank and sprays the fluid outward too. the motor that spins the little fan thing DOES work still, but the little fan thing and the round part that the hoses connect to may just be no good. thats as best as i can describe what it looks like, but im sure someone knows what im talking about and what it looks like. whats that little part called and where should i look for one, i dont know if an auto parts store would have something like that. its just the little round part that the hoses plug into and the metal prongs on the motor bend over it to hold it into place. (not the wiper motor, theres two different motors here) ps. i know the lines arent clogged either, i cleaned them out a few weeks ago. to better understand what im talking about, i drew a pic of what it looks like: http://i15.photobucket.com/albums/a367/pctvman/oo.jpg
PeteA216
05-31-2007, 04:26 PM
I'm sorry to tell you that the motor comes as one whole piece with the pump already attached. As far as I know you can't but a replacement pump to go on the motor. I've tried in the past and had no luck at any of my local auto parts stores.
mike561
05-31-2007, 04:28 PM
damn, i was debating to look at one of those self serve salvage yards but i wasnt sure if i'd be getting someone else's broken one too. come to think of it, i have seen replacement ones but they are all square shaped, mine is round obviously.
NocturnalCreations
05-31-2007, 06:30 PM
did u pull the hose off the pump and see if it comes directly out the pump. If it does, start hooking up one hose at a time to the pump until the fluid stops coming out and that'll be ur problem
mike561
05-31-2007, 06:35 PM
yeah i did that, i put my finger over the intake too and i diddnt feel any suction.
PeteA216
06-01-2007, 12:42 AM
The square ones you see are the original type that use a cam and mechanical power from the wiper motor to move a piston back and fourth that pumps the washer fluid. I got the electric motor retrofit, probably like what you have in your car. Bring the motor to an auto parts store and have them get you a new one. The motors/pumps are generally universally used on many different makes and models.
mike561
06-01-2007, 12:44 AM
so basicly i can get a retrofit for the existing pump motor i still have (since it still works) and it would look something like this with the retrofit: http://www.rockauto.com/catalog/getimage.php?imageurl=http%3A//www.smpcorp.com/web_app/catalog/images/WWP2212.jpg
PeteA216
06-01-2007, 12:48 AM
It should if it's the original motor.
mike561
06-01-2007, 12:55 AM
yeah i belive it is, or at least it looks like it. ill take it to the auto parts store and have them check it out too and see what can be done, i'd really like to DIY since its easy first of all, and to save $$ of course.
beat88ls
06-02-2007, 02:17 AM
i replaced the one on my 88LS and am looking to replace the one on my 83 this weekend. the replacement for my 88 was only $40 dollars at the local C.A.P. store. and last i checked the one for the 83 is about the same
mike561
06-02-2007, 03:18 PM
alright good to know, ill have to check it out
