Exhaust noise questionA. Dent 05-31-2007, 11:51 AM I noticed the rear of my 99 XJ squeaking yesterday. First I thought it was suspension but then it began to happen at idle while standing still. I parked it and left the engine on so I could check it out. Looks like the exhaust hitch had come loose of the hook it fastens to. The horseshoe-shaped bracked on the actual pipe if still there and tight/making no noise, it is the part that this loops onto to hold the pipe to the frame that has the problem - the horseshoe loop and the bracket are loose and rattling/squeaking. I pushed and pulled it back on the hook and the noise seems to be gone. My question is - should I worry more about this? A quick fix might be to just wire it tight onto the hook but I'm not sure. FYI, I have no lift that would have made this a problem. Thanks for any help. fredjacksonsan 05-31-2007, 01:55 PM It shouldn't be a problem, I'd just keep an eye on it to make sure it doesn't disconnect again. If it does, you may want to look into some new exhaust hanger parts. Automotive Network, Inc., Copyright ©2012
