Who know what radio adapter kit is Used ona P11
redvalkrie
09-12-2001, 03:54 PM
We share a big fat bose double din, when we convert it to a single dine what are some of you using to hold the radion in its aprpriate hole/slot meaning what kit did you buy?:confused:
Adapter kit for stereo install, brackets trim pocket all those goodies?
Please put in part# or by any chance has some one called crutchfield & got a part# & pricing?????:bloated:
ty423
09-16-2001, 02:47 AM
Didn't I already tell you how??? write this down...on my car I used my stock bracket and used a pocket from a 1997 Nissan Pathfiner....try that..worked for me...got lucky because our headunits harness fits on to my moms pathfinder so she got a new double-din and I have a single-din but Alpine now...
redvalkrie
09-17-2001, 09:54 AM
I tried it I still had a gap around the radio, maybe its just the kenwood excelon deck that I put in.
I used the original brackets wich were a pain to get off the OE radio, then I bought a universal pocket.
The Pocket looks great but I have a small gap around the radio on the top.
That is why I was wondering if the was a specific Kit for the G20.
ty423
09-17-2001, 11:03 AM
OIC....hmmm...did the kenwood come with a frame??? My frame for the face was too big so I had to shave the ends to fit....but before it used to look like the face was sticking out but that was only cuz I had no face on it...now I do...looks alot better.
redvalkrie
09-17-2001, 11:05 AM
Yeah the trim plate for the face is to big for the opening I was thinking of shaving it but I am not sure itf it is going to look tore up!:rolleyes:
ty423
09-17-2001, 11:39 PM
I used a dremel and slowly shaved off while measure onto the unit to see how much more to do...it worked for me...just try to shave in an angle which you can't see any damage from the front of the face...try to shave evenly...that is the key...
G20RIDER
09-17-2001, 11:51 PM
Hey ty423.....do you know what double din model might fit the G20.....maybe a sentra has the same configuration......
ty423
09-18-2001, 02:51 AM
double din shouldn't be any problem it should just screw right in with the stock bracket....I am 80% sure...
redvalkrie
09-21-2001, 11:05 AM
Ok people so here is a rundown of what I have learned to install a single din Radio in a doulbe din slot!:rolleyes:
1._ First remonve the entire panel that houses the radio the air controlls, 2 screw's on the bottom neear the shifter( if you put your head near the shifter look up at the radio you will see 2 scew's)
2._Steadly pry off trim plate that house the above components be gentle when pulling near the top there are some inserts that hold it in place give it a gentle tug, towards you!
3._Disconnect all accesories there are small tabs on the wiring conectors they will be very stif so use a small screw driver to press the tabs & at the sam time pull away from you slowly.
4._Unscrew radio, 4screws. Unplug radio wiring harnesses from rear!
5._Brackets are held on to the radio by 8 screws (4 on either side). These dame screws are held in by I belive welds, can't really see the back of them so this is what I did: "I used my dremel/drill put a very small bit on it & drilled the center of them out increasing my size of bit until the screw just gave". I tried just about every thing to get these bastards out that was the easiest way.
Things u must buy b4 installing new single din "Deck".
1._Wiring harness for your vehicle, makes it a lot easier than cuting/splicing & taping/soldering.
2._Antenna adapter for your vehicle.
3._universal pocket kit from stereo shop.
Installing ur single din radio!
1._ Makke the proper conection to ur radio via the wiring harness b4 hooked up in the car! "Double check all your conections".
2._Plug in Antenna adapter to The antena in car.
3._ Ready to put in radio(remeber to have the battery disconected that should of been done b4 this hole processs)
4._ Conect wiring harness, Antenna adapter while hanging freely conect battery just to check you will be disconecting again. Check ur functions check all conections making sure there tidy.
This is were you might want to do the stock wiring look, rap all visible wires with black electrical tapeNot Necessary but looks good
5._ (disconnect battery again) Slide in radio with caution.
Screw in all 4 screws. Check your wires for any sharp kinks.
6._ Conect battery do some finale check makes sure every thing works properly.
7._ Re-install trim. Don't forget the 2 screw you have to put on. Tighten batery conection!
You are done! =)
If I left anything out or if any body recomends an xtra step please feel free to add!;)
