94' tranny question
SuazoInTheSticks
05-29-2007, 06:37 PM
Alright heres the deal. I have a 94 with a straight 6. It has an automatic 3 speed with a puch button overdrive. This tranny went out on me and I'de like to go with a tested and trusted C6 tranny but I dont know if my truck will even start with it cause of the electronics. If all it does is make my check engine light come on all the time then I'm fine with it but I really cant afford the grand to fix the one that I got but I can afford to get me another one. So long as the thing will bolt up, run, and switch gears. Thats all I care about. And if someone has another route that i can take I'm listenin.
tabernacle tranz
08-24-2007, 11:23 PM
Alright heres the deal. I have a 94 with a straight 6. It has an automatic 3 speed with a puch button overdrive. This tranny went out on me and I'de like to go with a tested and trusted C6 tranny but I dont know if my truck will even start with it cause of the electronics. If all it does is make my check engine light come on all the time then I'm fine with it but I really cant afford the grand to fix the one that I got but I can afford to get me another one. So long as the thing will bolt up, run, and switch gears. Thats all I care about. And if someone has another route that i can take I'm listenin. yes the c-6 will work but:nono: you will have to change the drive shaft,crossmember,flyweel,mount,run vacum line,gear for the speedo you would spend more money changing it over then just fixing the E4OD tranny thats in the truck but if you have a freind in the junk biz who will help you out then good luck :rofl:
