Google
Web AF
See Latest Posts
Old 05-29-2007, 05:21 AM   #1
white_R34
white_R34's Avatar
white_R34 Normal reputation
Arrow 3-Part Howto's making wing/Steering w. cord
Hello New How to's
for all of you who have dun this this first one will not help you, it's for you all who have not tryed using the Decals in the Tamiya kits for the tires. I show images with words. The info on the sheet says and I quote:How to Apply Decals to Tires
Tire decals have adhesive on the surface. Be careful not to touch this surface at any time, or it will become soiled.(Dirty) {I have found you can touch it and it will still work just try not to.}
[1] Wipe dust and oil from surface with damp cloth.(I used decal setting solution to clean the tire off){do not use softening solution on tire}
[2] Cut out decal with a modeling knife, then remove protective paper using the edge of a knife blade.(Image of hobby knife helping pull up decal)
my image
[3] Place decal into position, then rub lightly with your finger.
[4] Lightil apply moisture with a wet finger.(I used a paint brush)
After it has soaked into the paper, remove the paper and wipe off the excess moisture with a soft cloth.
What they look like on F1 car.
That was part 1
Next part 2 Making a Steering Wheel CordImages and Text)
you'll need some Detail Master Ignition wire(colors up to you),1/8 Brass or Alum. Tubing,super glue. smallest dril bit you have.
[1] Rap the wire around the drill bit(image 1) then pack it down (image 2).
the packing it down helps you make the cord longer.
[2] Cut small peace off brass or alum.tubing and super glue ti over the wire's edge to the steering wheel. "completed part"
[3] use colored Flat Acrylic paint if you use white wire.(what I used and the colored cordimage's 1-2)
Completed project wheel and cord on car.
Next part 3 Making a lower replacement wing for my F1 car in images. (NO TEXT)
I don't know if any of this stuff is no here or not; but I hope it helps some one.
white_R34 is offline   Reply With Quote
Bookmarks
Google
Web AF
