airbag fault code?
colinsZ24
05-27-2007, 04:07 PM
dad has a 92 taurus, airbag light is flashing.. ive been searching around and found out that that is an LFC (lamp fault code) but i cant find the code anywhere. can anyone help? i posted this video of the code, to me it seems like code 42. flash flash flash flash (pause) flash flash, maybe someone can help me? lol thanks in advance!
-colin
http://www.youtube.com/watch?v=MvZsD3eOtVM
shorod
05-27-2007, 04:35 PM
Yep, that's a code 42. According to the factory service manual, that code indicates "Center Radiator Primary Crash Sensor Feed/Return Open."
-Rod
colinsZ24
05-27-2007, 06:18 PM
thx alot for your help, but do you have any ideas what it could be. we checked for plugs by the rad and for the rad cap to be on all the way. so far seems fine tho.
shorod
05-27-2007, 11:05 PM
The code would indicate there appears to be an open circuit condition in either the power or the ground circuit. I try to stay away from diagnosing airbag issues since they can become dangerous and expensive in a hurry if you don't have the proper tools, so I don't have any more advice for you.
-Rod
colinsZ24
05-28-2007, 01:07 AM
ok thanks, i;ll let him know.. and follow up when/if fixed
lectra
05-28-2007, 08:53 PM
The first thing I would consider doing is pulling the steering wheel and unplugging the trigger plug (found behind the air bag device itself, the passenger's side airbag can be disabled the same way without removal). After that, I'm wondering if a volt/ohm meter could fire the air bags. A Hayne's manual would be very helpful here.
