95 lumina transmission fluid linesDav9 05-26-2007, 04:16 PM I replaced the metal transmission fluid lines that go into the radiator because they had rusted through and were leaking. The new line keeps leaking at the fitting to the radiator between the line and the flare nut, not around the threads. Any suggestions? lanerd 05-26-2007, 07:13 PM Im not quite sure what you mean but you might try a layer of teflon tape... otherwise I haven't the foggiest. 1993LUMINATOR 05-27-2007, 12:20 AM if l understand what your saying..................then take the tranny connector off and clean the metal where the connecter sits then tightin it all togather. if not when in doute get rubber hoses and Clamp that bitch Dav9 05-28-2007, 02:13 PM I tried removing and cleaning everything several times but it still leaked. I noticed some small flaws in the new metal lines where they fit into the radiator. I ended up using a single wrapping of graphite faucet packing between the end of the line and the flare nut and the leak stopped. NocturnalCreations 05-28-2007, 11:36 PM sounded like the tube wasnt flared right wafrederick 05-29-2007, 08:03 PM Sounds right to me,not flared right.You are supposed to double flare,not to single flare.If ever going to hoses,flare the end where the hose is going to be slipped on and clamped.If you do not do this,the hoses will blow off real easy and will burn up the transmission real easy. Automotive Network, Inc., Copyright ©2012
