2000 Tahoe Z71 no power when punchedhortonm 05-24-2007, 10:44 PM My 2000 Tahoe z71 with 5.7 V8 is acting up. Over a 3-4 month period, I've noticed a problem climbing hills in a hurry (like when I get on the parkway). I thought it was the tranny slipping, but when I brought it to my Tranny guy, he gave the Tranny his blessing and indicated the engine was losing power which felt like slipping. As long as I don't "punch it" flooring the accelerator, I can drive it reasonably well - took it on a 5 hour drive to the mountaiuns last weekend. My mechanic suggested the catalytic converter was blocked (I have 170K miles on the car) and I had him replace the "y" pipe last weekend. I picked it up today, still has same problem - In a bit of craziness on my part, I checked to make sure the airfilter didn't look clogged and even drove it a mile or so w/o the filter to see if that would help - no good. If I fllor it, the engine does not rev more that 3000RPM. This may have nothing to do with it, but i hit the reset button on a sensor in the duct from the filter to the carb. Engine now revs well past 3000RPMs as has much more pep, but runs a bit ragged and stalls too. Any ideas? MT-2500 05-25-2007, 10:18 AM How many miles on tune up? Plugs and filters and basic tuneup? Any check engine lights on or flashing? The reset button is only a air filter condition tester. Has nothing to do with engine running. hortonm 05-25-2007, 04:09 PM couple of years since tune up - probably 40K miles, noticed filter wasn't seated right, there was a gap in the case when closed - closed correctly now - drove it about 60 miles today - still running rough, particlarly at start, but full power now - thinking about bringing it in for full diagnostic test - no check engine or warning lights on MT-2500 05-25-2007, 06:03 PM Good diagnostic check may help. Also check fuel filter and fuel pressure. Good luck and let us know how it goes. MT TejasDan 05-26-2007, 12:19 AM I'd suggest a Diagnostic check... I had a somewhat similar problem in my truck - Same Model/Year. Turns out I had over-oiled my K&N Filter and the oil had dripped down and screwed up the Mass Airflow sensor. Mechanic hooked it up, pulled the code and solved the problem. Automotive Network, Inc., Copyright ©2012
