Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina APV
Old 05-21-2007, 07:15 PM   #1
discnik
discnik Normal reputation
Angry P0361 Code, 94 Lumina, 3.8L
We have a 94 Lumina, 3.8L, vin"L". Pulled codes, P0361 EST line not toggling, & P0321 No 18X ignition pulse. The vehicle originally came in with a no start problem. Had a cam sensor code and the afore mentioned codes. Thought perhaps the 361 & 321 had to do with the crank sensor. Replaced both sensors. Vehicle will start and run but under accelleration has severe missing problem. Also replaced plug wires as there was arcing visible. Waiting on a EGR valve, code P0406, EGR pintle position error. Main question has anyone ran across the 361 & 321 codes ? If so what do they pertain to ? Especially the 361 code. Thanx.
discnik is offline   Reply With Quote
Old 05-22-2007, 10:02 AM   #2
LMP
LMP's Avatar
LMP Normal reputation
Re: P0361 Code, 94 Lumina, 3.8L
IN my book P0361 reads: ignition coil K malfunction....and P0321 is ignition coil/engine speed input circuit range/performance..so it figures with your perception of "missing"..one coil or ignition module could be suspect. Just for a test, I'd swap a pair of coils one for the other (taking note of the proper markings) just to see if the error code will change with the coil position.
I don't believe in miracles.
LMP is offline   Reply With Quote
Old 05-22-2007, 02:34 PM   #3
discnik
Thanks for the input. By the way what "book" did you look this up in ?
Old 05-22-2007, 06:05 PM   #4
LMP
LMP's Avatar
Originally Posted by discnik
..what "book" did you look this up in ?
One is the book/cd that ame wth my code reader, the opther is a list I had taken some time ago from the internet with a search for pontiac OBD2 codes..copy here:
www.avigex.ca/xport/allpontiaccodes.txt
..ah..still there:
http://myweb.accessus.net/~090/dtcobd2p.html#pow notice code P3000
By the way, your interpretation of P0321 and the one I gave are near equivalents.
Bookmarks
Google
Web AF
