325 Ci 2003 A/C prob, please help!!!sal5pointo 05-21-2007, 06:21 PM I have a 2003 E46 325Ci. My problem is that the A/C will not work on Auto. it blows out hot air from the vents, and the vents are set to blue, not red. The only way that i can get cold air to come out of the vents is if I put it on Vents and Floor. The vents blow cold and the Floor blows burning hot! so my feet suffer, and My face gets cold, but the overall temp of the car is never comfortable. I have taken the car to BMW for the compressor and an A/C charge so this is not the problem. I have had several suggestions, but no one can narrow it down. stepper motor, water valve, blower motor resistor, i just don't know. but i do know it is hot and I need my A/C. any help is very much appreciated. thanks bmwe36i 05-24-2007, 11:45 AM I have a 2003 E46 325Ci. My problem is that the A/C will not work on Auto. it blows out hot air from the vents, and the vents are set to blue, not red. The only way that i can get cold air to come out of the vents is if I put it on Vents and Floor. The vents blow cold and the Floor blows burning hot! so my feet suffer, and My face gets cold, but the overall temp of the car is never comfortable. I have taken the car to BMW for the compressor and an A/C charge so this is not the problem. I have had several suggestions, but no one can narrow it down. stepper motor, water valve, blower motor resistor, i just don't know. but i do know it is hot and I need my A/C. any help is very much appreciated. thanks well i think there is aproblem with the gate(s) that switchs the air pathway from the compressor and hot air coming from the engine when u choose air to come from vent (for instance) this gates must move so it prevent air from the engine to blow out and only allow air from the compressor to blow out check this gates and see ..... bmwe36i 05-24-2007, 11:45 AM I have a 2003 E46 325Ci. My problem is that the A/C will not work on Auto. it blows out hot air from the vents, and the vents are set to blue, not red. The only way that i can get cold air to come out of the vents is if I put it on Vents and Floor. The vents blow cold and the Floor blows burning hot! so my feet suffer, and My face gets cold, but the overall temp of the car is never comfortable. I have taken the car to BMW for the compressor and an A/C charge so this is not the problem. I have had several suggestions, but no one can narrow it down. stepper motor, water valve, blower motor resistor, i just don't know. but i do know it is hot and I need my A/C. any help is very much appreciated. thanks well i think there is aproblem with the gate(s) that switchs the air pathway from the compressor and hot air coming from the engine when u choose air to come from vent (for instance) this gates must move so it prevent air from the engine to blow out and only allow air from the compressor to blow out check this gates and see ..... BAVARIANM 05-24-2007, 02:50 PM faulty water valve ladagosta 08-22-2010, 12:10 PM Sal do you still have your 325ci? if so can you assist with a wiring issue I would be so grateful to get mine back on the road instead of it becoming a lawn ornament.. thanks I have a post I need to ID where 2 wires connect.. simple as that and without access to one locally I am a sitting BMW.. thank you in advance if you would be so kind to pop your hood and find these 2 wires and let me know where they are supposed to go.. again thanks Automotive Network, Inc., Copyright ©2012
