Please Help. 91 Lumina 3.1 Water Pump replacementbradleyz34 05-20-2007, 02:04 PM Hello. The water pump on my 91 Lumina 3.1 is shot. It leaks out all over the belt and onto the ground. We were wondering if there was an easy way to remove this and replace it instead of having to take the entire front of the engine off. Does anyone know the best and easiest way to go about this and maybe include a short step by step process. We have removed the belt, coolant tank. Thank You maxwedge 05-20-2007, 07:18 PM Go to autozone.com/repairinfo for an online repair guide, this is not a hard job. frank6060 05-20-2007, 08:24 PM Easiest water pump replacement I ever had was on my 90 3.1. Remove belt,pump pulley,bolts around pump,pry out carefully. Clean gasket surface and install new pump. you can take your time and still be done in a couple of hours. Automotive Network, Inc., Copyright ©2012
