Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > NSX
Old 05-19-2007, 07:30 PM   #1
Saxman885
Saxman885 Normal reputation
Twin-turbo Skyline engine in an NSX....
So before anyone laughs at me for even bringing this up I was wondering:
Do you think the skyline engine would fit in the NSX?
I would tend to think so seing as the skyline is a straight six, so it should be a bit more narrow right?
The reason I was asking is because the naturally aspirated NSX engine has a compression ratio of 10.2:1 and Please correct me if Im wrong but wouldnt reving at 7 or 8 thousand rpms with more than 10 lbs of boost cause the engine to detonate/blow?
The highest hp I have seen on an NSX is around 430 or so running twin turbos at 7-9lbs however, I see skylines (compression of 8:5:1) pushing in excess of 600HP and they redline at around 7,500 right?
What do you think? yay or nay?
(I'm not looking to be ridiculed just educated)
Saxman885 is offline   Reply With Quote
Old 05-20-2007, 10:12 PM   #2
AudioGuy93DelSol
NA is Best!
AudioGuy93DelSol's Avatar
AudioGuy93DelSol Normal reputation
Send a message via AIM to AudioGuy93DelSol
Re: Twin-turbo Skyline engine in an NSX....
First off, it's basically impossible because the NSX is a mid-engine rear drive vehicle, whereas the Skyline is a front-engine rear drive vehicle. The transmissions are set up for completely different cars so it wouldn't work.
Second, you can build a C32 (NSX engine) to be low compression or high compression. You can also stroke or de-stroke it. The same holds true for a the skyline motor. Your horsepower potential with either motor is basically limited to how much money you have but I guarantee there are NSX's with way more than 430hp.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
AudioGuy93DelSol is offline   Reply With Quote
Old 05-21-2007, 09:22 PM   #3
Saxman885
Ok well in that case, do you think that this turbo kit is a bunch of Bullsh**?
http://www.turbochargedpower.com/91-...cura%20NSX.htm
I have heard nothing of this kind of power before except on:
http://www.daliracing.com/v666-5/inf...ion/index.html
supposedly it had like 700hp...
Old 05-22-2007, 12:30 AM   #4
jeffolsoned
Banned
jeffolsoned Normal reputation
isn't the old bmw m1 the only post ww2 mid engine sports car with an inline six?
a supercharged nsx sounds cool
jeffolsoned is offline   Reply With Quote
Old 06-26-2007, 08:56 AM   #5
OppositeLockNSX
OppositeLockNSX Normal reputation
I don't think its bs at all there's a guy on the NSX boards NSXPrime that has a 95X with over 120k stock bottem end, stock heads, stock trans, Gt35R (big turbo LOL) and all of the basic things needed for a turbo setup nothing special. Ohh and a stage 3 clutch and flywheel. He ran a 10.78@136. The cars I see doing that are right around 500wheel plus. So I would say that kit is very on target.
-Taylor
OppositeLockNSX is offline   Reply With Quote
Old 10-24-2007, 11:09 AM   #6
Schister66
AF -Advisor
Schister66's Avatar
Schister66 Normal reputation
Send a message via AIM to Schister66 Send a message via MSN to Schister66
although i basically agree with the rest of your post, in this part, you arent correct. Im not going to argue the technicalities of it; however, space confinements aside, this has been done already. The Tommy Kaira ZZII uses an RB26 with upgraded turbos in an MR setup that still uses the AWD capability of the RB26. I cant say for sure if the tranny is the same, but it has been done nonetheless...
Make: Tommy Kaira
Model: 2003 ZZ2
Powertrain Layout: Mid-engine / 4WD
Base Price: $100,000 +
Weight: 1000 kg / 2204.6 lbs
The new build is underway...
Borg Warner S256 + 9.8:1 built GSR + E85 = 450whp Daily Driver
Schister66 is offline   Reply With Quote
Old 03-24-2008, 06:45 PM   #7
speed5676
speed5676 Normal reputation
why would you want to swap a v6 that has a bigger bore than the skyline's rb26, basically nsx's engine is more powerful than the skyline's? yeah maybe the skyline is a supercar but if u dig up the engine and compare with the nsx's, nsx is more powerful
speed5676 is offline   Reply With Quote
Old 03-24-2008, 09:19 PM   #8
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Greenblurr93 Normal reputation
Send a message via AIM to Greenblurr93 Send a message via MSN to Greenblurr93
Please dont bring up old threads. thanks.
Greenblurr93 is offline   Reply With Quote
Bookmarks
Google
Web AF
