Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > CL/Inspire/Saber/TL
Old 05-18-2007, 10:51 PM   #1
saroj
saroj Normal reputation
Acura TL 2003 Remote keyless help to program
Hi,
I just bought Acura TL 3.2, 2003; since the keyless remote didn't came with the car, I bought it seperate from ebay. Does anyone knows how to program. i really need big help on instructions how to programme.Your help will be appreciated.Thx
saroj is offline   Reply With Quote
Old 05-19-2007, 03:33 PM   #2
Onblsht
Authorized Vendor
Onblsht's Avatar
Onblsht Normal reputation
Re: Acura TL 2003 Remote keyless help to program
First, make sure you have the correct remote.
FCC: E4EG8D-444H-A.
Also, do you have memory seats in your TL? If so, make sure your remote says MEM 1 or MEM 2 on back.
For programming:
Do steps 1 - 12 on the same remote (AT TIME OF PROGRAMMING BOTH REMOTES MUST BE PRESENT SINCE THEY WILL NOW BOTH HAVE TO BE REPROGRAMMED.) The following steps 1-12 are done on a single remote step 10 is done on all remotes to be programmed up to 4 can be programmed
1) get into the car shut the doors (including trunk or tailgate) and make sure they are unlocked
2) turn on the ignition (do not turn on the engine just the ignition til the dash lights come on) (LISTEN FOR A QUIET CLICK)
3) press the lock button on remote (turn to off) (Do not remove key)
4) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
5) press the lock button on remote (turn to off )
6) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
7) press the lock button on remote (turn to off )
8) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
9) press the lock button on the remote
the locks should cycle to indicate that programming mode was entered successfully
10) press the LOCK button on each remote you want programmed and the door locks should cycle again to confirm programming. THIS STEP NEEDS TO BE DONE FOR EACH REMOTE
11) turn off the car fully and remove key.
12) try locking/unlocking with remote to test
to turn on/off the chirping when locking/unlocking with remote do the following
press the trunk release button on the remote and hold it then while holding press the LOCK button on remote and hold it the led on the remote will flicker for about 1sec after it goes off release both buttons and test it the procedure for chirp on and chirp off is the same, this needs to be done on both remotes otherwise only the one programmed will allow chirping while the other will still be silent or vise versa
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Onblsht is offline   Reply With Quote
Bookmarks
Google
Web AF
