Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon
Old 05-15-2007, 11:48 PM   #1
libby6485
libby6485 Normal reputation
need a little help
when we take right turns it stalls out and sometimes when i start it or its been running it feels like its spitting and sputtering like its gonna stall but it only does all this when the check engine light flutters on and off but when the light isnt fluttering its on if someone has had this problem before or knows what it is please let me know
libby6485 is offline   Reply With Quote
Old 05-16-2007, 11:47 AM   #2
das2123
Tuning Neons since '97
das2123's Avatar
das2123 Normal reputation
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: need a little help
Time for a tune-up? Check all your P/S fluid level.
96 ACR Sedan
das2123 is offline   Reply With Quote
Old 05-16-2007, 01:35 PM   #3
denisond3
denisond3 Normal reputation
Our 97 was quitting (engine would quit) when taking a right turn at low speed (such as after a stop sign). And it would only start after removing the ign. key and counting to 30 before trying to restart it. I replaced the cam position sensor - one of its two 'locking tabs' was broken off, and the connector and its wires looked ratty. I -think- it must have been making a bad connection, but I dont know. It was also oozing oil. I replaced the mating connector as well, since it came with the new cam position sensor. You have to be VERY careful not to let any of the wires from the wiring harness contact the steel tube that runs from the EGR valve forward to the bottom of the throttle valve. That tube gets hot enough to melt the wire insulation. You would only see this if you removed the inlet air tube running from the air cleaner to the throttle body, which you need to do when working on the cam position sensor anyway.
We had the problem of the engine spitting and sputtering - because it was idling too low when warmed up. I replaced the Idle Air Control Valve, and since I got such a nice discount at Carquest on the parts, I also replaced the Throttle Position Sensor. The idle speed was back to normal, and there was no more sputtering or stumbling.
Have you checked the 'codes' from the engine check light?
denisond3 is offline   Reply With Quote
Bookmarks
Google
Web AF
