Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Impala / Impala SS
Old 05-15-2007, 04:59 PM   #1
mjtr21
mjtr21 Normal reputation
CEL code P0440
I have had this light on constant for almost 3 months now. Before, it used to come on and go off. So I had the code checked and it was P0440. They mechanic said get a new gas cap. So I did and it went off but came back on shortly after. Ever since then it has not went out. I talked to my mechanic and he said there is a leak somewhere. Is this code for a leak or is there something wrong with one of the valves. I was told maybe the purge valve next to the throttle body could be bad. How would I check that? Well any other suggestions on the P0440 light woud appreciated. Thanks in advance.
mjtr21 is offline   Reply With Quote
Old 05-15-2007, 07:41 PM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: CEL code P0440
Any leak in th evap system can set that code, a smoke machine is the most accurate way to pinpoint the problem other than a visual of all involved hoses, lines and fittings.
maxwedge is offline   Reply With Quote
Old 05-16-2007, 05:55 AM   #3
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
Re: CEL code P0440
I agree with Max. This is one of those things where you need a professional piece of equipment (the smoke machine) to pin point the leak. It could be in any of the tubes from the engine compartment all the way to the tank. I doubt the evap purge valve would trip a P0440.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Old 05-18-2007, 02:49 PM   #4
mjtr21
Re: CEL code P0440
yeah i guess ill have to do that then. how much do you think it would cost to have that smoke test done? thanks.
Old 05-18-2007, 04:22 PM   #5
maxwedge
A990 racer
Re: CEL code P0440
Varies by region and shop, figure 1 hour labor.
Bookmarks
Google
Web AF
