2000 Outback overheats, loses coolant
Google
Web AF
Wildwrench
05-15-2007, 02:41 PM
Hi Everyone,
Rember when Subaru 'recalled' this car several years ago for head gasket leakage? The fix, at that time. was to add a few ounces of some kind of liquid sealant. Worked for me! That is until I had the cooling system flushed last Fall. I put in the same sealant but did not have time to run it much before I parked in over winter. A week ago, when I retrieved it from storage, it overheated in about 6 miles. I added coolant and drove it. Then did the same again several times. Finally, the leakage is down to about 1 cup in 100 miles. So, the problem is not really fixed but tolerable.
I have a 2400 mile trip to make in 3 weeks (through Canada). I'm thinking I need a permanent fix. I was quoted over $900 for replacing the head gaskets.
Should I continue to work with the additive or 'bite the bullet' and get new gaskets? Are there any other options?
Thanks for your help.
bertmaster2000
05-15-2007, 07:50 PM
I do not know if your car has more than 100K miles, but if it doesn't you should check out this link about possible headgasket replacement under warranty:
http://www.subaruheadgasket.com/0003.htm
The headgasket just went on my '97 (out of warranty) so I ordered a salvage engine and plan to install it myself as the fix...for me, money is too tight right now to go any other route!
best of luck to you!
Google
Web AF
