1995 Jeep Cherokee reverse light problem
GSmyth
05-15-2007, 12:17 AM
I have a Jeep 95 Charokee Laredo and my reverse lights do not work at all. I have done everything I can with the NSS and they still don't work. Would anyone have any idea what other reason there is why they don't work?
wwwildman
05-16-2007, 09:08 PM
Check grounds (a lot of times they get loose or the socket gets corroded)
Check fuses
Check bulbs
Check for power (with voltmeter)
GSmyth
05-16-2007, 10:36 PM
Thanks for your reply. Where are the fuses located?
wwwildman
05-24-2007, 07:32 PM
Check under dashboard, to the left of the sterring column(as if in the driver's seat}. You can miss it!
jlc55
08-21-2007, 04:10 PM
i have a 95 jeep cherokee and also have problems with reverse lights not coming on..if i jiggle the handle somtimes theyll turn on...any1 have any idea?
inafogg
08-21-2007, 04:43 PM
jlc55 it sounds like switch could be misadjusted. its on steering column underneath dash
jlc55
08-23-2007, 03:59 PM
switch misadjusted?? the handle is in between the seats...
inafogg
08-23-2007, 04:47 PM
sorry is yours a automatic with floor shifter? if so switch is under shifter plate. i was thinking of a column shifter
citizen@large
08-23-2007, 07:47 PM
Reverse lights are often affected by the NSS (neutral safety switch) Being able to actually start your rig is also a concern with a filthy NSS. It just needs in most cases to be removed and cleaned.
http://jeepin.com/features/nss/index.asp
That should get you started. Just getting a new one costs a ton compared to cleaning it.
