code 25lood 05-14-2007, 05:37 AM Hello I got code 25 (idle air control motor circuits) anyone know how I coul\d fix this. Thanks das2123 05-16-2007, 11:45 AM Pull it out and clean your IAC. It is mounted on the TB. lood 05-27-2007, 10:30 PM Whats the IAC and TB. Thanks Novum 05-27-2007, 11:53 PM The idle air control valve can become dirty. You may need to spray carb cleaner in the idle air port. This cleans the buildup off of the valve. Also a vacuum leak or a very dirty or faulty pcv valve can cause this. I hope this helps. das2123 05-29-2007, 09:16 AM Whats the IAC and TB. ThanksIAC has been answered and TB=Throttle body. Automotive Network, Inc., Copyright ©2012
