94 4.3 (w) changed CPI, now running very rough
Just looking for opinions as I have some concerns. Will try to keep this short.
This is a 1994 4.3 litre Vortec with "W" in the VIN. Just for clarity.....
As I was about to leave a car wash, while attempting to start my Jimmy, it actually fired, then back fired. Towed the truck home and found my cylinders to be full of fuel and determined my CPI had failed open. Replaced the CPI, actually quite an easy procedure but now my engine runs very rough and when I took it for a little spin, there was some pinging. I actually let it idle for about ten minutes before taking it out on the road hoping the computer needed to lean with a new CPI in place and adjust some settings.
Did the oil change of course, new plugs, cap and rotor. Plug wires are fairly new so I decided to wait and see on those.
Does this sound like timing to you good folks?
I had done some searching here and appears I have to locate a brown wire on the passenger side inside the cab. Can anyone be a little more exacting on it's location and type of connector it uses.
I have a Chiltons book on my Jimmym and this is a quote from it.
Most later model vehicles are equipped with a single wire timing bypass connector. On these later model vehicles the bypass wire is usually a tan wire with a black stripe. This wire usually breaks out of the wiring harness conduit adjacent to the distributor. But on some vehicles this may brealk out of a taped section just below the heater case in the passenger compartment.
No where though does it explain what I should do with this.
SlugHog
