Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 05-11-2007, 09:02 PM   #1
porkchopsocr
porkchopsocr Normal reputation
keyless entry woes
My keyless entry stopped working on me, and I cant figure out what it is. I've changed the battery on the remote, but nothing.Any advice would be great. Its for a 2003 Blazer.
porkchopsocr is offline   Reply With Quote
Old 05-13-2007, 11:54 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: keyless entry woes
TRY A TRANSMITTER RESYNCHRONIZATION
Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the remote control door lock receiver (RCDLR).
The RCDLR will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter.
Resynchronization may be necessary under the following conditions:
If The battery in the transmitter is very weak.
If The battery in the transmitter was replaced.
If the car battery has been run down weak or dead
Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds .
The horn should chirp in order to confirm synchronization.
MT
MT-2500 is offline   Reply With Quote
Old 05-16-2007, 07:35 PM   #3
Onblsht
Authorized Vendor
Onblsht's Avatar
Onblsht Normal reputation
The 7 second resync is necessary on most GM remotes if you change the battery on one that was completely dead.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Onblsht is offline   Reply With Quote
Bookmarks
Google
Web AF
