Re: 2001 Bravada Misfire/hesitates
Is the 01 The new body style? I know that the 02 actually came out in 4/01. I had an 02 with the same issue. Only thing I had you did not mention was the engine light coming on and off. Turned out to be a bad coil assembly, which on the 02 (check yours) is one per cylinder. Mine only acted up when the engine heated up and under load. A good indicator is the condition of the plugs. The culprit cylinder the plug was destroyed. Not dentonated, but carboned ruined, etc. Did you notice a plug worse than the others when you pulled them? Easiest thing is to pull the ODB codes One of the autoparts chains has a machine they let you use. Good luck, and I hope that is not your issue because the parts, and especially the labor to get to the coils is big $.
FYI, just reread your post before I sent this. You did not mention the airfilter. Sounds basic, but if you didn't check that, they clog up pretty good, and airflow under load could also be the cause. Also, the fuel filter, which should be external on the tank or frame rail, clogs up pretty good also. Acceleration and load needs more fuel pressure. When is the last time that was changed?
smacit2ya
