1992 Cherokee engine swapjimr66 05-11-2007, 03:52 PM I have a 1992 Cherokee Laredo bad engine 4.0 litre I have access to a 1993 4.0 litre to swap in. This engine is complete from the head to oil pan will this be a direct bolt in or do I need the wiring harness or the CPU from the 93? Thanks to all. Jim citizen@large 05-12-2007, 02:00 PM Yeah, it should go straight in, but I'd get the harness and CPU as well. Just in case. You never know dude. jimr66 05-15-2007, 10:57 AM Thanks to all who replied I went ahead and bought the 92 cherokee, 4.0 litre auto, I had mentioned that I was going to swap out the engine with a 93 model. When I went to look at and purchase the 92 the lady said it had a ROD KNOCK, I started the XJ it made a slight to moderate clacking noise but stopped after starting. I drove the XJ home Aprox 15 miles no noise whatsoever on acceleration or deceleration. It does blow smoke when sitting for a minute or two. could this just be a bent or cracked push rod? or piston slap? has anyone encountered this before? thanks everybody Automotive Network, Inc., Copyright ©2012
