05-11-2007, 12:55 PM
question about key clutch....
I am going to be putting on that steadfast security collar to go around the ignition, it came with its own clutches and the instructions say to pry off the little shiney peice where you put your thumb and finger on when you turn the key. does that just pry off or is there some type of clip that has to be released with it somehow? i want to do this right without breaking anything
05-11-2007, 06:58 PM
Re: question about key clutch....
http://www.steadfastautosecurity.com/steadfast.pdf if this is the product you have it looks like it snaps off and is replaced by there part to compleat the install. in the past when that chrome piece is popped off its broke. what i haved used is a hidden switch under the dash that disconnects the 12vdc wire to the distributor preventing the car from starting. cost 3-4 $ look on the thiefs face priceless. 463
05-12-2007, 06:23 PM
I don't understand how that thing works.
My three current vehicles:
05-12-2007, 08:06 PM
I don't understand how that thing works. " what thing ? " PeteA216 you ask
05-12-2007, 08:16 PM
AF -Advisor
vbmenu_register("postmenu_4755462", true);
huh?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
PC Club is dead. Long live PC Club!
05-12-2007, 08:34 PM
what is PeteA216 asking about ?
05-12-2007, 09:08 PM
I think he's asking about that collar (which i cant seem to get to fit the right way)
05-12-2007, 09:33 PM
i agree with 463 it looks like it can be removed after installed. i personally have the lockiit, comlumm lock and i was told i would not be able to remove it and i was. it is still around the column only problem is tha i lost the piece that enages to it that wraps into the steering wheel.
1987 Chevy Caprice LS 4.3L, 700R4 Trans.
Shaved Handles and Rear Deck.
Pearl Paint Job
05-13-2007, 12:50 AM
Yeah sorry for the delay, I was talking about the collar... I don't understand how a collar around the steering column could help to protect against vehicle theft. Is it simply to keep the column from getting smashed?
05-13-2007, 02:21 AM
AF -Advisor
Yes, it prevents access to the locking mechanism. I am sure you've seen pictures (or even the real thing) where a column was broken to gain access to the rack/gear which allows one to start and drive the vehicle with the key in the lock position. This collar reduces that risk by adding "armor" to the column.
05-13-2007, 01:03 PM
yeah, it looks effective but im pissed because i cant get it to fit properly around the column, and i know its the right one for that colum too. i may have to end up sending it back, hope not though.
05-13-2007, 11:32 PM
My grandfather's Caprice was stolen that way. They smashed the window, then the steering column the the trunk latch and whatever they kept in the trunk smashed out the walls of the trunk as they drove. This was back 13 years ago... the car's been long gone since then.
05-13-2007, 11:35 PM
i think my best bet would be to get like what i had in my other caprice, was an alarm with a cutout switch
