Uplander Blinkergoskins20001 05-11-2007, 11:32 AM How do you change the front left blinker light in a 2005 uplander??Does is it pull out or do I have to take apart the spoiler/bumper to reach it?? Thanks '97ventureowner 05-11-2007, 01:39 PM To remove the front left turn signal you must first remove the headlamp assembly. To do that you must first remove the headlamp retainer pin which is on top of the assembly towards the left as you look at the front of the vehicle. You remove it by turning the pin towards the headlamp assembly and pull it straight out. Next you remove the screw from the top of the assembly going towards the fender. The assembly can now be pulled away from the van. From there you should be able to see the socket with the turn signal bulb. Turn the socket counterclockwise to remove it from the assembly. You can now remove the old bulb from the socket and replace it. Put the socket back in and turn clockwise to install. Put the headlamp assembly back on the van, tighten the screw that was removed from the top, and put the pin back in it's place and turn in the opposite direction you did to remove it. That should be it. goskins20001 05-14-2007, 10:12 AM Thank you Automotive Network, Inc., Copyright ©2012
