Runs fine wide open, but not at steady speed
I am stumped. I have an 89 s10 blazer 2wd 4.3 automatic. While trying to maintain a steady speed it acts like its running out of gas. If you maintain steady pedal position, in about 3-5 seconds it'll come back, but start acting up again in a couple secs. If you punch it when it starts acting up, you almost immediately have full power. It stalls on occasion at idle and the idle surges. I have changed the plugs, wires, cap, rotor, the distributor (because i broke it), the fuel filter, the screen on the fuel pump (because I drained out some bad gas. It sat for almost a year). I have driven it about 300 miles so I dont think I can blame it on sitting.
Now to make it more interesting. It doesn't act up when its cold. And when its acting up, if I shut it off and restart it it'll be ok for a couple minutes. I get an intermittent code 32, something about a vacuum switch for the egr valve I think. Will the egr system make it run like this? And how do I know which one to change? When the light comes on it seems to run better.
Any help would be appreciated. Thanks.
