How to set Piston 1 to TDC (Top Dead Center)
smillan05
05-09-2007, 03:40 PM
I was doing about 80 yesterday when my car died!!
Timing belt busted…………:banghead:
How do I set the No. 1 piston to TDC (top dead center)?
How much would it cost to get my valves redone, if damaged?
What mods do you all think that I should do, since I will be taking it apart?
Thanks!!
1989 Honda Prelude 2.0 DOHC (B20A5)
CivicSpoon
05-09-2007, 04:56 PM
Get a wire coat hanger, and bend it straight. Take off the plug wire and pull out the plug in the #1 cylinder. Put the coat hanger down the hole and turn the crank until the coat hanger is at it's highest position.
Greenblurr93
05-15-2007, 07:25 PM
i usually have a friend cover the plug hole with his finger and feel when the piston is pushing aire around his finger... that way you know its on the compresion stroke and not the exhaust stroke.. also.. i would put the cams to TDC first.
wiseguy01
08-19-2007, 05:24 PM
mistake
Greenblurr93
08-19-2007, 06:26 PM
ok, this is getting annoying.. again, please read the forum rules and guidlines before posting
wiseguy01
08-21-2007, 06:35 PM
ok your getting annoying forum police are you cause you think your all bad trying to be mr know it all
Greenblurr93
08-21-2007, 06:39 PM
1. I never said i knew it all.
2. there are rules for a reason, if you want i can get a mod involved
3. dont go around pissing people off or your stay here wont be long or enjoyable..
wiseguy01
08-21-2007, 06:41 PM
well lets see how good u are and i have no idea how to talk to u directly so im using this forum and i retracted some of my posts
wiseguy01
08-21-2007, 06:42 PM
how do you talk to each other like I.M.
wiseguy01
08-21-2007, 06:44 PM
retracted
Greenblurr93
08-21-2007, 06:45 PM
its called a PM (private message) on this forum. click my name, and then send private message
orb666
08-30-2007, 08:19 AM
1. Remove Valve Cover
2. Loosen all spark plugs (remove upper timing belt cover to see the camshaft marker)
3. There is a marker on the lower timing belt cover like a "\/" thing
4. There are markers within the crankshaft pulley (3 lines that are close together and 1 line that is far from the 3 lines)
5. Align the marker from the lower timing belt cover to the crankshaft pulley (1 line)
6. Make sure the "UP" sign marker on the camshaft pulley is on the upside (Piston 1 @ TDC position)
7. If the "UP" sign marker on the camshaft pulley is on the downside (Piston 4 @ TDC position)
*be sure to turn the crankshaft pulley "COUNTER-CLOCKWISE"!!!
wiseguy01
08-30-2007, 11:40 PM
read forum rules before you post again this thread is more than 2 months old
Greenblurr93
08-31-2007, 06:52 AM
lol. trying to take my job away from me? i thought i was "MR. Forum Police" :grinyes:
wiseguy01
08-31-2007, 10:13 PM
lol
Tony Silva
01-19-2011, 05:03 PM
i usually have a friend cover the plug hole with his finger and feel when the piston is pushing aire around his finger... that way you know its on the compresion stroke and not the exhaust stroke.. also.. i would put the cams to TDC first..
ok....so with the timing belt broke.....THINK ABOUT IT.
Greenblurr93
01-19-2011, 07:11 PM
Care to elaborate what im supposed to think about in this dead thread?
