strange noise from rear endhondahappy86 05-08-2007, 10:56 PM when i go to take off.....it sounds almost as if my rear end is binding ......what do you think it could be.....note its a 9c1 with the 8.5 rear end.....non posi silicon212 05-08-2007, 11:38 PM Is it like a grinding sound that's constant in pitch and you can hear real good at lower speeds? If so, likely axle bearings or axle shafts are the culprit. If it's a whine that varies in pitch, corresponding with vehicle speed, that would indicate a gear mesh issue - i.e. wear or incorrect mesh/lash. If it's a clunk when you put it in gear, that could indicate wear in either the pinion/pinion bearing or U-joint. hondahappy86 05-09-2007, 12:07 AM it is a growling noise at low speed.....and the only time i get a whine is when i slow down....i guess either way i need to rebuild my rear axle anyways silicon212 05-09-2007, 12:37 AM Yep, sounds like axle bearings. Automotive Network, Inc., Copyright ©2012
