Stalling Problems
95 K1500 5.7 w/TBI
I recently installed a reman engine with new sensors/switches/PS pump/batt and cables/clutch and fork/Dist, cap and coil/plugs and wires/vac lines and hoses/waterpump and cooling hoses. TBI rebuilt w/ new injectors, new fuel filter. Same starter and solenoid/alt/ac comp/fuel pump.
I set the timing and for one day, it ran like a champ. The check engine light is on, and I haven't had it cleared or checked yet. Was going to go to a shop close by to have it scanned and/or cleared, and on the way there, the truck was running fine until I would turn a corner. If my RPMs were high enough, it was ok, but if the RPMs dropped as I was turning, say to come to a stop, the truck would die, and it would only do it if the truck was in a turn. All the electrical stuff would stay on, IE; lights, gauges, etc. The truck would start right up afterwards though. I just drove it back home in case it was something serious, so I haven't had a hance to check it out.
Any info would be greatly appreciated
