motor swapjonill 05-07-2007, 01:37 PM Does anyone know if you can put a 1994 1.9L motor in a 1998 saturn car. Cat Fuzz 05-08-2007, 01:52 AM You will need an EGR valve adapter. 98 uses an electric EGR valve while 94 uses a vacuum EGR valve and they bolt up different. The adapters are kinda hard to find from what I understand. The fuel injection might be different also. jonill 05-08-2007, 08:59 AM Does any body know where I can get a EGR valve adapter kit for the older heads that I can use with the newer cars. richpin4real 05-08-2007, 09:29 AM Does any body know where I can get a EGR valve adapter kit for the older heads that I can use with the newer cars. Try your local wrecking yard or pick-a-part.This web site has a good reputation. http://www.saturnautosalvage.com/ Automotive Network, Inc., Copyright ©2012
