91 S10 RWAL ProblemJMW_50 05-06-2007, 07:16 PM I am getting a Code 4 on a 91 S10 with RWAL brakes. Code 4 is an anti-lock valve stuck open. Which valve are they talking about? There are other codes for the Isolation and Dump valves. Anyone have any idea. Thanks JMW MT-2500 05-06-2007, 10:26 PM I think it is the valve reset switch in the ABS pcm. Check your PM. JMW_50 05-06-2007, 11:36 PM I already replaced the ELectronic Control Unit. The Schmatic I have shows the reset swith being part of the Isolation/dump valve module which is attached somehow to the combination valve. I not sure exactly what it does. I am not sure how to test it without just replacing it, but it is a fairly expensive part and it looks like a pain to change. MT-2500 05-07-2007, 09:37 AM I already replaced the ELectronic Control Unit. The Schmatic I have shows the reset swith being part of the Isolation/dump valve module which is attached somehow to the combination valve. I not sure exactly what it does. I am not sure how to test it without just replacing it, but it is a fairly expensive part and it looks like a pain to change. As far as I can ll the reset switch is made inside the ABS module/pcm. Did you get the PM I sent? If so go threw the ohm check out test outlined in it. Let us know how the test goes. MT Automotive Network, Inc., Copyright ©2012
