transmission question
Google
Web AF
|97BlaZeR|
05-06-2007, 08:33 AM
When my transmission is cold it shifts hard from 1st to 2nd after about 3-5 minutes of driving it will shift fine... is this just because the fluid is cold maybe?
And also is it normal for the torque converter to lock when i have extra weight in the truck? a few weeks back i cramed a 150lb table w/ about 10 lb of folding chairs (yes it was packed full to the brim) + me (130lb) in the back and for the first time since i got the truck about a month ago the torque converter was locking.. usually when i just do my daily driving it just goes into OD and it doesnt lockup
thanks
edit- its a 97 blazer lt 4x4 4dr
MT-2500
05-06-2007, 10:30 AM
How many miles on it?
Has the transmission ever been serviced?
Any check engine light on?
Engine running up to par?
Fluid level and fluid condition?
There is a lot OF TSB's on the harsh 1-2 shift.
But we need to know if any or what no. transmission codes are set in the transmission pcm.
|97BlaZeR|
05-06-2007, 12:05 PM
135,000 miles
tranny rebuilt/flushed 15,000 miles ago
no check engine light/codes
MT-2500
05-06-2007, 02:42 PM
How much of the transmission was rebuilt?
New converter or valve body rebuilt?
Did it do it before or right after rebuild?
First step is to get a transmission capable scanner on it and read out transmission codes and data.
Watch the pressure solenoid data and shift delay data in the scanner.
|97BlaZeR|
05-07-2007, 03:18 PM
not sure how much of it was redone, the previous owner had it done and showed us the receipt to prove it, i dont have the reciept anymore so i cant confirm.
it was about 78 degrees today and it shifted like a charm, ill keep an eye on it, but at this point im not going to worry.
Google
Web AF
