Help, running rough *cough*
ekubota1
05-05-2007, 09:03 PM
I've got a 1990 cherokee sport, it's the 4.0L I6. It's running very rough, idling shuddering, and dying on the road. It has new plugs/cap/rotor/oil change etc. It has oil coming into the air cleaner, and a ton of oil sitting on the rockers under the valve cover. It's not smoking out the back. What can it be? Please help me save my jeep!
wwwildman
05-05-2007, 10:23 PM
The oil in the aire cleaner is probably caused by oil blowby from the CCA. Check the hose running from the back/top of the valve cover to the manifold for cracks or blackage. You might want to replace that whole assembly, only $22 dollars at dealer.
The rest of your problem could be serveral areas:
MAP sensor, IAC, TPS are the most common. I would start there with testing.
citizen@large
05-06-2007, 03:14 AM
Helpful links towards the above advice: Sensor Diagnostics.
http://www.lunghd.com/Tech_Articles/Engine/Basic_Sensors_Diagnostics.htm
What's a CCV(A)?= Crankcase Ventilation System. "I think that's what he's saying..."
http://www.autozone.com/az/cds/en_us/0900823d/80/15/25/87/0900823d80152587/repairInfoPages.htm
~Good Luck. - Let Us Know...
wwwildman
05-06-2007, 08:37 AM
Thank citizen, CCV was exactly what I meant...getting older is for the birds!
gobedo
03-21-2009, 04:32 PM
Not sure this is the problem, but a jeep mechanic that started his own shop fixed my problem. the car just ran bad at low speeds but a little better at high speeds. now one could figure out the problem except him. Anyway it was a stupid little hose on the fuel pump in the fuel tank that had shrunk and was sucking air. He replaced the hose on the pump For $90.00 and my 1990 jeep ran good again.
Hope this helps
