does anyone know of any info on step-by-step to changing the front axel?? online or if you know how and you can help me?? any help will be appreciated!! thanks!
Remove wheel
Remove axle nut - may be very hard without air tools
Remove lower ball joint nut
Pop out lower ball joint either by hitting the lower control arm with a hammer near the joint or use a pickle fork
Remove lower strut bolt
Push axle out of hub by pulling on brake caliper and pushing axle in
Pop out axle from trans
Remove axle from suspension by pulling down on lower control arm
