1990 Cherokee - Clicking no start.
mn90cherokee
05-04-2007, 10:45 AM
I searched the forums and was unable to find an answer to the issue of when I try to start my jeep all I hear is "clicking". I appologize if I just can't find it and this is repost of someone elses previous question.
Background:
Jeep has sat outside for 2 years without attemtpting to start. I charged the battery and the lights are working so I assume there is power. If I try to start the jeep it just makes a clicking noise.
I understand that there is probably several possible causes so I am wondering where to start. Should I replace all the cables and wires from the battery to the starter? Is there a simpler way to determine the cause?
thinmints
05-04-2007, 08:38 PM
I would just take the starter out and go have it tested
citizen@large
05-05-2007, 03:06 PM
^^x2^^
Then try replacing both battery cables etc... Start with the least co$tly things 1st.
~Good Luck!!
~PS- All I wanna hear is, "She's ALIVE!!!" http://i9.photobucket.com/albums/a86/lexycutie69/emoticons/th_th54e6c16e.gif do it. DO IT.
AlohaBra
05-05-2007, 09:45 PM
Electrical testing is usually done using a voltmeter to determine the problem. A load test is used to test the battery.
citizen@large
05-06-2007, 03:23 AM
Starters can be tested right? (never had to do it.)
Aloha, I've seen 'The Goose' wait on your electrical expertise. Is my thinking wrong? Why, if so? Thanks...
Shoot-Dang! I do declare! I FULL - ON Special Request a stickie-basic XJ electrical troubleshooting thread from you my friend!!! Because it's something I/we need help in/on... THANKS!
~Hakuna ma tada? lol
AlohaBra
05-07-2007, 12:13 AM
Yep, 12.6 volts at the Bat.. to start..when you crank...it drops to about 10.5 or so...but needs to above 9.6V.
Those are the numbers.
One day, I'll find a link for this, but electricity is like plumbing.. bigger the pipe, more flow. Smaller pipe is causing resistance and less flow. Voltage is pressure. Amperage is like gallons per minute....
