need some help with my bagged 99 s10kengoman 05-03-2007, 07:53 PM I got a 99 s10 2.2 auto.... i have heard they are notorious for the ground for the fuel pump and my fuel pump was (occasionally) working so i pulled the bed and changed the fuel pump.... now I got fuel and spark but i cant get it to start...if i spray some starting fluid in the intake it will want to fire and occasionally without.... anyone tell me their ideas on it? I am thinking the fuel pump i put in isnt giving enough pressure maybe? Jason Wallace MT-2500 05-03-2007, 08:07 PM Welcome to AF. Go easy on the starting fluid. Carb cleaner is a lot safer. Dis you check and or clean the ground wire for fuel pump? You might check all fuses. Put some extra gas in the tank. May be to low to pick up fuel? Can you hear the fuel pump prime up on key on? But you need to get a fuel pressure gauge on it to make sure you have the proper fuel pressure. Post back pressure readings. MT kengoman 05-03-2007, 08:15 PM thanks for the welcome.... I am 99.9% sure that the fuel pump isnt pushing the right pressure i went back out and hit the pressure valve on the fuel line atop my motor and it had a small squirt(not even usualy spray) and then stopped so im going to just take the fuel pump back and exchange it.... My bed is still off anyhow so its not bad to do :P Jason Wallace MT-2500 05-04-2007, 07:27 PM A large or small squirt does not tell much about fuel pressure. Does the fuel pump prime up key on? Or can you hear it run on engine crank? Has it got power on prime up and ground to fuel pump? MT kengoman 05-05-2007, 01:37 AM well this is my fourth 99 s10 and before it was an almost evaporative spray that came out.... now its just a piddle... i can hear the pump priming up when i turn the key and it is still pumping when i crank it Jason Wallace blazee 05-05-2007, 07:32 AM kengoman, This site has a strict policy against advertising. Please refrain from plugging your site in all your posts. MT-2500 05-05-2007, 09:58 AM well this is my fourth 99 s10 and before it was an almost evaporative spray that came out.... now its just a piddle... i can hear the pump priming up when i turn the key and it is still pumping when i crank it Jason Wallace Put 5 gallon of gas in tank and try it. Also check fuel filter. MT kengoman 05-05-2007, 03:59 PM sorry about that its just habit to type my info in.... and MT i have a full tank now and its not working im going to head home and change the fuel pump and check that out Jason Wallace Automotive Network, Inc., Copyright ©2012
