'92 Celica ST, Won't Start. 1.6L 4A-fe.bleomoran 05-03-2007, 05:29 PM Was driving today and the car shut down. Engine check. OBD I NO CODES came up. Car cranks but no spark at the wire while grounding out with screwdriver. Replaced the coil, the ohm numbers were good but just replaced anyway. The distributor cap and rotor are new. I checked the timing belt. Teeth on cams and rubber belt were good. 3/4" play in the belt. I have to see if the rotor and timing belt turns when I crank it. M.A.P. sensor or ignitor (in distributor)? 143,000 miles. Need help gang. Thanks, Brian.... toolmor 11-09-2008, 07:18 PM did you ever get fixed???? I have same problem just wondering what you found?? Crawlin Around 11-09-2008, 11:56 PM I had the same problem a couple days ago and replaced the coil and it fired right up for me. Automotive Network, Inc., Copyright ©2012
