2002 SL1 Rear knocking noisedylanzachgabby 05-03-2007, 01:30 PM Hi my father in law has a 2002 SL1 it makes this weird knocking noise in the rear end when driving, any help... Cat Fuzz 05-03-2007, 04:07 PM Could be a bunch of things from bad tires or wheel bearing to dead squirrel caught up in something. You just need to crawl up there and take a look. dylanzachgabby 05-03-2007, 06:48 PM The tires are new, and theres no squirrels, could be the wheel bearings, would both sides need to be replaced. longlacryan 05-03-2007, 07:03 PM could also be the rear strut mounts or shocks. also check for clearance around the exhaust system. heat sheild could be touching yaz4real 05-03-2007, 08:19 PM Don't exclude the exhaust system including the muffler strap as a possiblity. A visual as you push on this and pull on that should yield a result. Automotive Network, Inc., Copyright ©2012
