My Daughter has a 97 Chevy Cavalier that is not overheating but the "Low Fluid Light" stays on and does not go off...I checked the fluid level and all is well...When I look into the fluid I see that it is dark and does not look green as prestone looks...Does the Cav need special fluid in the radiator??? or will prestone do just fine....Also could the problem be the sensor, can i remove it and clean it, do i need a new one??? Help as I cannot get thru inspection in NJ with this light on....Thanx in advance for your wisdom...Allen
