No spark to the plugs?brandini 05-02-2007, 05:51 PM I have a 91 cutlas supreme V6. It died on me at a light and now it wont start the plugs are not getting a spark we have replaced the computer, ignition module and coil packs! Please helo us figure out what is wrong we are stumped! caddyman379 05-02-2007, 06:00 PM Crank and Cam sensors should have been checked before you replaced any of this. brandini 05-02-2007, 06:09 PM hmmn the Crank and Cam sensors is this an internal part? how would i go about checking it? maxwedge 05-02-2007, 07:42 PM Get a scanner on it and see if you have cranking rpms, if none suspect the cps rear of block lower r/s, all the fuses are ok? brandini 05-03-2007, 06:32 PM Yes all the fuses are okay that was our first check! caddyman379 05-03-2007, 11:20 PM Get a scanner and see if you have cranking RPMs, as Maxwedge said. If you can't find one, and REALLY REALLY try to-then you could replace the crank sensor with a junkyard one to see if that's the issue. Crank sensor is located behind Harmonic Balancer (Crank pulley) Invest in a repair manual! $15. Typically. Automotive Network, Inc., Copyright ©2012
