1990 Honda Accord water pumpchuy38 05-02-2007, 11:25 AM Where is the water pump located. Sitting on driver's side. left or right side of engine. Put water in radiator started leaking on right side of engine. Hope its the water pump. Greenblurr93 05-02-2007, 11:36 AM water pump is located where all your pulleys are. you should be able to see it once you take off the timing belt cover. jonnyald 05-02-2007, 11:39 AM Where is the water pump located. Sitting on driver's side. left or right side of engine. Put water in radiator started leaking on right side of engine. Hope its the water pump.its at the belt side of engine, and not too tricky to replace. wiseguy01 08-19-2007, 05:17 PM retracted Greenblurr93 08-19-2007, 06:25 PM ok, no new tech in this old thread you brought up... please read the forum rules and guidelines before posting Automotive Network, Inc., Copyright ©2012
