where is the fuel filter?S10SNODOG 05-01-2007, 09:16 AM I have a 2003 s-10 crew cab pick up is it hard to change the fuel filter and where is it thank you in advance? S10SNODOG 05-01-2007, 09:17 AM sorry it has the 4.3 vortec motor in it MT-2500 05-01-2007, 09:23 AM Usually down on the side of the frame in transfer case area. Follow the big fuel line from tank to the back of the engine. MT S10SNODOG 05-01-2007, 10:46 AM thank you so much that should be changed how often thanks MT-2500 05-01-2007, 01:18 PM They are a change As needed deal. Normal conditions check/change ever 25K Depends on how clean you fuel is. Pull it off and see if you can blow threw it good if not replace it. S10SNODOG 05-01-2007, 01:50 PM cool yea I just bought a Purlalter one $ 22.00 no big deal no special instructions right just thread one end on and looks like a snap other end on duke350 05-03-2007, 05:53 PM Thats about it, but you may wish to put a bit of anti-seize on the threaded side to make it easier to change next time. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
