Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > N2O/Turbo/Superchargers
N2O/Turbo/Superchargers Tech forum to assist in Honda/Acura Performance.
Old 05-01-2007, 12:11 AM   #1
MK4R34
MK4R34 Normal reputation
JR Supercharged civic won't pass Emissions!!
I have a 97 SOHC Civic(OBD11) Jackson SC that won't pass EMISSIONS!!
keeps saying "not ready"for the O2 , cat and evap
My friend hooked it up to a wideband O2 and the fuel fluxuates just a lil when in boost not too lean/rich runing about 60psi on the FMU
Anyone have this problem??or the same set up with no problems???
What kind of set-up do you have to pass EMISSIONS!!!!
MK4R34 is offline   Reply With Quote
Old 05-01-2007, 09:58 AM   #2
Schister66
AF -Advisor
Schister66's Avatar
Schister66 Normal reputation
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: JR Supercharged civic won't pass Emissions!!
The FMU is your problem...get a chipped p28 (www.j-k-tuning.com) with the map for your engine setup and it should be a lot closer to passing....if it doesn't pass with just the new ECU, get that tuned and you will pass with no problem if you have a cat....
I would hate to have to deal with emissions laws...right now i'm running open downpipe and nobody cares....
The new build is underway...
Borg Warner S256 + 9.8:1 built GSR + E85 = 450whp Daily Driver
Schister66 is offline   Reply With Quote
Old 05-01-2007, 05:11 PM   #3
MK4R34
So keep the FMU and get a p28 chipped...and if that doesn't work with the chipped ECU then get it tunned....I have an OBD11...so in Atlanta they just hook it up they don't crank it....what keeps showing up is CAT-O2-EVAP are in"Not Ready"mode...wouldn't a p28 show up as a different VIN#???
Old 05-02-2007, 01:31 AM   #4
superbluecivicsi
AF - Advisor
superbluecivicsi Normal reputation
if your going to boost........who cares. i never passed smog with my old jrsc on my b16. just pay to pass under the table.
the ecu is not ready, because, the ecu keeps getting reseted every time you turn the ignition on. theres a short somewhere. check your ig1 and ig2 wires. its a good time to find an excuse to buy a helms so you can get the wiring diagrams . since theres a short somewhere, may i ask if you are running any of the jr bandaids. you may have not put some of the spliced wiring back together correctly or poorly as far as the cat goes. more than likely, your cat has taken a crap. as for the evap cel goes, there are a few different ones. specific codes would be nice. also, since you have the jrsc in there. you may want to check if any of your evap lines are kinked or open somewhere wouldnt hurt to get a vacuum gauge to verify
throw away the fmu and pick some real engine management.
my old setup was. jrsc b16@ 11.5 psi. hondatas2b, rc 550s, water alky setup, 2.5inch kami from the header collector all the way back. even with JRs 6 psi pulley, i still failed smog. give the smog thing up if you want to pass smog, stay stock.
by switching the p28 which is an obd1 ecu into the obd2 you will fail right off the bat. heres what i would do in order of priority.
1. solve you cel problems.
2. toss the fmu and get some real engine management.
3. when your done toying around with the jrsc heat blower, get rid of it and do sohc turbo
99 JRSC@9.5 psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
superbluecivicsi is offline   Reply With Quote
Old 05-02-2007, 08:18 PM   #5
Schister66
AF -Advisor
Schister66's Avatar
i didn't know that the OBD1-OBD2 switch would make someone fail emissions......thankfully i dont have to care about them
Old 05-02-2007, 08:34 PM   #6
MK4R34
Yeah I have 3 friends that do emissions and they said OBD1 on an OBD11 wouldn't work....so the p28 chipped ain't going to fly for me...I'm still weary about chipping my P2P ecu....
Old 05-04-2007, 04:58 PM   #7
superbluecivicsi
AF - Advisor
you cant chip and program the p2p as it is an odb2 ecu anyways. the obd2 to obd1 conversion will work, but, not for smog purposes though. to properly run your jrsc setup, you will need to run some kind of stand alone engine management.
jrsc on fmu = high intake temps = detonation
Old 06-28-2007, 10:32 AM   #8
Greenblurr93
Kind of a Big Deal
Greenblurr93's Avatar
Greenblurr93 Normal reputation
Send a message via AIM to Greenblurr93 Send a message via MSN to Greenblurr93
get an o2 simulator, it will trick the ECU into thinking your emissions are fine and you wont get an emissions code.
Greenblurr93 is offline   Reply With Quote
Bookmarks
Google
Web AF
