Re: B16 turbo which cams to use
An LS tranny on a torqueless B16 is going to suck...the longest tranny you should use is the GSR.
Cams: The GSR cam is a step up from the B16, the ITR/CTRs are a step up from that....I wouldn't recommend the Crower cams for a VTEC engine...only the non-VTECs (Crower 404). If you want a cheap upgrade, look for ITR/CTR cams, GSR or anything with similar specs like the Blox Type A.
Another thing to remember with the cams is that you gain a little from just putting them in, but gain more once they're dialed in so remember to get a set of cam gears as well....
The new build is underway...
Borg Warner S256 + 9.8:1 built GSR + E85 = 450whp Daily Driver
