Passlock bypassjustin0717 04-29-2007, 02:35 AM Alright after reading about everyones posts about passlock problems, and bashing GM and all this SH#$. Ive decided to share my info on the problem. First off ive got a 99 GASE 3.4, second ive bypassed the passlock. I wasnt having any issues with the car not starting, i was installing a remote starter, which obviously wont work with a theft system :p . Well anyways, alls i did to bypass the theft system was, (dont quote me on the wire colors :uhoh: ) But i believe it was yellow and black :dunno: . Its the only two really small wires on the lock cyl housing. Alls i did was sodder a resistor between the two wires (couldnt even tell you what Ohm it was I just tried one for SH*%$ and giggles). Then i did the 10 min key relearn, and there you go. I did this last summer, and havent had a single issue with the theft system, my car has always started (besides when my alt and battery went :uhoh:). Again dont quote me on the wire colors, and maybe i lucked out and put the right resistor in there. But i havent had a single issue with passlock since this. I hope this helps some people. xeroinfinity 04-29-2007, 07:07 PM Yes, it probly was the yello wire. When all one needs to do to usually fix the pass lock issues is to replace the ignition switch and or the lock cylinder. But I guess those parts are not cheap. Automotive Network, Inc., Copyright ©2012
