Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Nova
Old 04-28-2007, 01:09 PM   #1
Murph8868
Murph8868 Normal reputation
Nova rear end conversion
I want to change the rear end in my 77 Nova with a rear end that has disk brakes and is strong. I was told the 79-81 firbird / trans am rear end would bolt right in and they came with disk brakes so that would be a fairly cheap solution. just want to make sure that the info I was told was correct. any other ideas or vehicles that are interchangeable?
Murph8868 is offline   Reply With Quote
Old 04-30-2007, 08:37 AM   #2
bobss396
bobss396's Avatar
bobss396 Normal reputation
Send a message via AIM to bobss396
Re: Nova rear end conversion
Try this site, Team Novas. They have a forum, classifieds, etc. You should find an answer there.
http://www.novas.net/
bobss396 is offline   Reply With Quote
Old 06-07-2007, 01:39 PM   #3
Frasers73
Frasers73's Avatar
Frasers73 Normal reputation
http://www.automotiveforums.com/vbul...highlight=posi
"Yes, but it takes a little bit of work. 70-81 Z-28 and Trans am rears are about 1" wider than the Nova's rear. 82-up are no good!!! I put an 80 Z-28 posi rear with 3:42's in mine. The rear tires get moved out about 1/2" on each side, but you'd never know it from looking (see the pic of my car below). I run 225 60 R 15's with no problem. I have run 245 60 R 15's with no rubbing but they are just a little too close to the wheel lips for comfort. This is what I did for my swap: cut the spring perches off the new rear, center the new rear in the Nova and make sure the pinion angle is at the same angle as the original Nova rear, mark the location of where the new perches have to be welded, make sure to double and triple check your measurements, get a set of Nova perches and weld them on (I recommend getting a professional welder to do this because those axle tubes are pretty thick" - NOVA71
check these sites out for interchangeability info:
http://rmcavoy.freeshell.org/nova_parts.html
http://www.oldengine.org/unfaq/leadfoot/discs.htm
Frasers73 is offline   Reply With Quote
Old 06-09-2007, 12:28 AM   #4
molhannah
molhannah Normal reputation
It might be easier to do a aftermarket rear disc swap. Check ebay for kits.
molhannah is offline   Reply With Quote
Old 06-18-2007, 11:22 PM   #5
71NOVA02
71NOVA02 Normal reputation
I agree with molhannah, rear conversions are fairly cheap. might be cheaper in the long run to just spend the 400 rather than try to adapt parts. I was looking to do the same swap, but I have found that junk yard usually want way too much for a decent complete rear end anyway.
good luck - zach
71NOVA02 is offline   Reply With Quote
Old 06-21-2007, 10:51 PM   #6
trip-l-jax
trip-l-jax's Avatar
trip-l-jax Normal reputation
Try stevesnovasite.com really good info opcorn:
ASE Certified Automoive Technician-16 years
Surface Maintenance Mechanic- INARNG
trip-l-jax is offline   Reply With Quote
Bookmarks
Google
Web AF
