engine turns over but will not start
cajunbaddgirl
04-28-2007, 12:43 PM
new alternator, belts,plugs, and ignition coil. engine turns over but will not start. coil has fire in and out but not to plugs. :banghead: HELPPPPPPPP
mightymoose_22
04-28-2007, 01:21 PM
The plugs won't get anything to them if the crank sensor is bad or unplugged. Check the connector to the sensor on the front of the engine. It is under the oil filter and pointed at an angle toward the crank.
If the engine is turning over and you know you have power to the coil... I'm not thinking of another reason the plugs wouldn't spark unless they weren't getting that signal.
